Results 1 to 6 of 6
Thread: ABS and Nanocom
    Stewartp Guest
    Unhappy ABS and Nanocom
    Hi, I have just received my Nanocom and I am learning to use it. I have the ABS, ETC and HDC lights on on my 2002 Disco II dealer has reset them twice and they say it is the FL speed sensor. The only fault the Nanocom finds is with the shuttle valve. I tried to clear the faults but they won't go away, and the 3 lights remain on . Can anyone help. Thanks in advance.
    McDisco Guest
    Stewart
    Im no expert, but your ABS modulator may be bung. If it is this may be why the Amigos are always there...then again I may be wrong.
    I hope it isnt your modulator cause that an expensive fix...
    Angus
    p.s- you may want to repost this in the technical section.
    Dont know if this post is any help, but rings a bell.
    No More 3 Amigo's?
    Rgds
    Pete
    May 2003
    On The Road
    Stewartp Guest
    Thanks for the advice
    By working through your replies I found a LR tech Bulletin 70/07/04/NAS (talks about earthing problems) on the shuttle valve fault. I will work through it today and let you know how I get on. Think I worked out why the Nanocam won't reset the fault. It is a current fault not a historical logged fault so after reset the fault is probably reoccurring.
    Stewartp
    Stewartp Guest
    Problem rectified
    Thanks again for your help. Problems was rectified by the switch kit for the modulator. keeping my fingers crossed
