Results 1 to 10 of 16
Thread: Broken Alternator Bracket RRC
    Oct 2003
    Godwin Beach Qld
    G'day Folks
    I have a technical question, 1985 Rangie 3.5 carby model, which has a broken alternator bracket, please don't tell me that I have to remove the Power Steering Pump to get it off bracket is broken at the lower mounting at the head/block stud, this would be the reason that the upper inner bolt left home, lucky it went down and under the vehicle and didn't leave via the Radiator this will be my little job for tomorrow
    P.S. the Rave CD is a little vague as to how it is removed, but, by the look of it, the bracket is located by the power steering pump.
    Douglas Park, NSW
    If it's the same as my '87 then the PAS pump needs to be removed. I didn't remove mine altogether though as the hoses allow some movement once the mounts are removed.
    Kippa Ring
    Just went downstairs and had a look at mine. Its located on the opposite side to the PAS and should be able to be removed on its own. Mind you I have the radiator and support panel out so it may be a bit more difficult with everything else in there. If you can post a photo of yours I can compare it to the one on the engine that is going on the scrapheap and I can remove the bracket for you as long as you arent in a screaming hurry.
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    95 Disco v8 - The Next Victim
    Oct 2003
    Godwin Beach Qld
    G'day jbarracl
    The bracket on mine mounts on the left hand side with the bracket behind the power steering pump, which is also on the left side of the block,it has the old tin type of PS reservoir also on the left, nicely nestled in with the 2nd battery. sorry I am not able to post a pic
    but would be interested in the bracket if it is of no use to you
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    i will have my welder out tomorrow after lunch if you want it welded...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Kippa Ring
    Mines on the drivers side so probably no use. Its an 81 model, they must have changed them somewhere along the line
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    Kippa Ring
    This is mine
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
    Oct 2003
    Godwin Beach Qld
    G'day jbarracl
    YUP! yours is on the opposite side to mine,but I would be interested in the alternater fan shroud as mine is missing looks like I will be removing my power steering unit to get access to the bracket and off to Inc's for a weld jobbie then put it all back together. after that I can get the headlamp relay wired in, so I can have decent reliable lights
    East-South-East Girt-By-Sea
    1.20 MB
    Uncle Ho
    Maybe I can be of assistance, I have 2 1985 Range Rovers and my daily driver has had 4 of the brackets in it's life. It seems that I get about 5 years or so out of each one. Welding only lasts a couple of years before it cracks again in the same spot.
    Graeme Cooper's have replaced the last 2 so it has been about 15 years since I did one myself. These days I get a new bracket each time, they last longer than the repair.
    From memory the bracket only shares one bolt with the PAS pump. I bolt is above the bolt for the pump on front of the valley, then there is the bolt on the front of the manifold and the only one that could be shared is the one underneath the pump, which from memory is one very long one. My recollection is that the pump stayed in situ but loosened off.
    In the picture you can see the bracket in gold passivated zinc, the bolt you can see adjacent the lifting ring is not one of the PAS pump bolts. You can also see that the bracket is sitting above the pump and drops down behind it.
    Sorry I can't be of more assistance.
    Diana
    P.S. Yes I know it doesn't look like a carby V8, but all the fittings are genuine 1985 model.
    Kippa Ring
    Quote Originally Posted by UncleHo View Post
    G'day jbarracl
    Not sure what I am going to do with the alternator yet. Not sure if it is the right one for that model as the pulleys are out of alignment. Cant figure out how the previous owner drove it without throwing a belt.
    Series 2 LWB - Gone
    Series 3 LWB - Gone
    Series 1 LWB - Gone
    81 RR 2 door - Gone
