Results 1 to 3 of 3
Thread: squeek front hub 110
    hi all hope someone can help had the change from grease to oil using maxi drive flanges on my 110 started to notice squeek from front wheel when moving. coming from hub there was a leak from the flange cap tightend that fixd it diff is full the cv swivel pin housing was grease does that change to oil with the maxi conversin squeek is now louder anyone any thoughts cheers
    Brisbane, Queensland
    I had a squeak after some work done on the hubs and front diff.
    I was told the spring that holds the hub seal was not sitting right or had got caught in something and was rubbing.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    See my post in your other thread.
