Results 1 to 10 of 27
Thread: Balancing front prop. shaft.
    Frankston, Melbourne
    Hi folks.
    I have replaced the Uni's. in the front prop. shaft.
    Like a goose, I didn't mark which components were up, down, this way or that.
    I now have a slight vibration under certain conditions.
    I am thinking, I either have an unbalanced prop. shaft or the Uni problem was only an indicator to a larger problem (260,000 ks).
    Any thoughts?
    Melrose SA
    Did you assemble the shaft out of Phase??
    Thats the way it was when it was manufactured
    Quote Originally Posted by djam1 View Post
    Quite probably!
    I made sure that the yolk on the driveshaft was 180 degrees out from one end to the other when I put it together.
    The sliding joint should have marks each side to show how it should be assembled. You may need to clean it up to see them. The ones I have seen are an engraved arrow on each part, which should be assembled pointing to each other.
    That's what it says in the Haynes manual!
    But, for the life of me I couldn't find any identifying marks.
    I just had to consider rotation and try to balance the thing by sight, so to speak(i.e. grease nipples opposite, yolks opposite, etc...)
    Are you suggesting I pull the whole thing out and have another look?
    I don't mind! I want it to work. But...?
    Bump... Anyone please?
    mike 90 RR Guest
    Quote Originally Posted by discomuzz View Post
    This is a brand new front propshaft from the RRC 1990
    I "think" the "out of phase" for this model is "29 degrees"
    The problem with yours is it is out of balance as you have lost the spline markings .... and just changing the uni joints is enough also to throw it out of balance ..... hence "have lost the balance of the shaft"
    Have a look at mine
    You might as well spend the $100 and get it done properly ... as a unbalanced shaft will cost you on diff & transfer box seals & bearings
    Hope it helps
    Yinnar South, Vic
    Getting perfectly good hsafts balanced is a load of crap, they don;t go out of balance unless something changes, either you've incorrectly fitted the uni's or the worng ones, or most likely the phasing of the prop is out,
    1. fit it together so both the inside the flanges are "in phase", then pull it apart and turn it "out of phase" 1 spline and refit
    2. promptly report back here, preferably with pics
    mike 90 RR Guest
    Quote Originally Posted by rovercare View Post
    Now there's the hint of the problem
    But he has lost the "line up marks"
    Propshafts would be "naturaly balanced" except for the welding and the way they are constructed .... As they are not "true" for being straight ... most of them have a slight bend in them ... from being welded // ect
    My thoughts anyway
    Yinnar South, Vic
    Quote Originally Posted by mike 90 RR View Post
    My thoughts anyway
    That's why they are balanced from factory, but unless the wieght drops of or something changes, a dent etc, then there is no need to rebalance
    I've got quite a few shafts made by my mate, all statically balanced, not dynamic and all work well
