Results 1 to 10 of 25
Thread: P38 Radiator what options?
    Aug 2008
    Wagga
    What options are there for the replacement of a P38 radiator?
    Is there only one type or did they make a better one (more cores and bigger) that still fits? Anyone got any idea of price?
    Mine works OK but yet to test under load but temp does climb when car is moving very slow on a hot day - otherwise stays constantly in this position (Temp about a mm above half way).
    I am going to flush and swap coolant first and see what i can see blocked cores.
    Radiator bloke told me that if it starts getting hot that with the plastic tanks they cannot get a replacement tank and thus probably better just to replace the whole radiator.
    Remy
    Ringwood VIC
    From what I understand the only difference was the top hose location (left or right).
    I'm definately interested in this as I believe it to be a major weak point with these cars.
    Stu
    s/w metro of sydney , australia.
    re radiator
    i dont consider radiator the weakness unless blocked with rust , i found a design fault in the non activation of the twin fans in frount of the radiator not comeing on at all ,air or no air (only came on once when top of radiator burst at 230,oookm).i drive also a vt holden and when i swich the air on ,fans work as well at the same time automaticaly ,in p38a when air is swiched on ,fans dont move .what i have done is crimped the 2 yellow wires together which go to the pressure switch part no btr9223 the lower one at frount pass side behind under frount bumper bar (done nothing else )so when air is on ,twin fans are on .found doing city deliverys temp stays constant half way stop start driveing no mather what ,were before between 1/2 and 3/4 more importantly before starter motor would play up in the heat sometimes ,since fans work starter has not been giveing me problems in stop start city driveing were i might use starter up to 50 times in a day doing my job .also oil level constant level now fans cool all the time ,its still warm in engine bay but nothing like before, at least i can touch the fuse box and not burn my finger on the yellow sq relay if i touch that as well . just try that before spending around 700 hundred dollars or so on a new radiator ,worked for me cheers .
    Oct 2008
    Frankston, Victoria
    Running a good radiator flush treatment and re-filling with a good properly mixed coolant fixed the problems on my 99 RR. I'll definately be looking at re-wiring the thermo fans as I've also noticed not coming on that often.
    I'd suspect a blocked core.
    This was mine:
    The radiator currently fitted may be Chinese! The coolant label on the top of the radiator is spelled "Coolent"!
    Like rofosixone's car, my electric fans rarely switch on. I suspect a faulty trinary switch.
    Aug 2008
    Wagga
    Got any pictures? any complications with this for the longer term? everything i have read on rangerover.net points out that the system is designed not to use the fans unless needed but i find it hard to believe that they have never been needed (as i have never seen mine on). Aslo lots about pressure of the gas being the activator. What if the gas is low? I have just fitted the kit to supply correct voltage (thanks Scouse) and seems to be working. i will take it for a run towing a trailer tomorrow.
    Remy
    Quote Originally Posted by rofosixone View Post
    Aug 2008
    Wagga
    Where is this switch. I am a bit confused. rangerover.net suggest on the thermostat. Rave suggests on the drier/finisher.
    Aug 2008
    Wagga
    see post
    Re: Electric cooling fans not operating-
    Postby Garvin on Mon Aug 25, 2008 4:07 am
    If the main engine cooling (viscous drive) fan is working correctly then the condensor fans will rarely activate as the air flow through the radiator and will be sufficient to cool both the engine and the air con condensor in only but the hottest ambient temperatures. The condensor fans will only operate when the air con is on and the engine should be capable of maintaining 'its cool' without the air con operational. Now the condensor fans can mask a poorly functioning engine cooling system (poor fan, water pump etc) when the air con is on as the engine radiator will start to overheat and this will adversely affect the operation of the condensor causing the aircon to swich on the condensor fans to help cool the condensor. This will have the knock-on effect of helping the air flow through the engine radiator and thus cooling the engine. If the engine is overheating then it is not the fault of the condensor fans ........... but, of course, that doesn't mean they are necessarily working :wink:
    re radiator answer
    yes by rights viscos fan behind radiator should be ok but were not in england were in australia its hotter here ,but i noticed off road and when i sometimes take the rangie to work instead of vt i notice in stop start traffic in sydney it gets so hot.as said vt fan comes on at 104 than stops at 94 and if air con switched on fan comes on all time ,in rangie nothing ,in mine as yours always 1/2 way but it sometimes rises in sydney stop start to 3/4 .my radiator flows fast when flushed and has no rust (did buy new at 230,000km ),but talked to auto electrician and said british do it different way to holden .so as said (and told )crimped the yellow wires just before the lower air switch btr9223 ( not the one up higher were drier is ) behind frount bumper pass side and doing that makes the fans come on when you switch air con on ,if you turn off air con ,fans stop working .if you pull out the plug that goes to btr9223 switch you get a book sign on your lcd air con screen in the cabin so i just leave plug in only crimping (joining the wires together with crimp ).and now as i wrote above there are benifits to this simple thing and nothing is affected computor wise ,i tried to put pic but can not but if you send me a email can send anyone a pic (know how to do it that way )were i have and what i have done to make it easy visually ,and as said before does work or else wouldnt have done it cheers, ralph .
    Aug 2008
    Wagga
    Rad
    OK i have emailed you for the pics - thanks!
    Radiator flushed and cleaned, core doesn't seem blocked from my limited viewing angle and fluid was relatively clean, green and not much dirt came out. Temp gauge still sits a mm or 2 above half. I guess this is just where it sits on mine. Towed the trailer for about 50km @ 110km/h, loaded, family as well, and A/C on full. Temp gauge stayed in the same spot (excellent). As for the fans jumped them at the relay and they work fine. But didn't come on at any stage - left the car running for about 20min stationary (temp stayed in the same spot). I know freon is a bit low as the A/C guy said it was when he informed me i needed a new compressor as the clutch kept disengaging (new wiring harness has fixed that). I will top the gas and if that doesn't allow the fans to start working crimp as per Ralph's suggestion.
    Thanks all Remy
