Results 1 to 10 of 39
Thread: Speakers for Defender - splits any use ?
    Bracken Ridge, Qld
    I have a 300Tdi Defender with the air con unit, so there are two speakers (one per side) facing down at an angle into the front footwells.
    These speakers are getting a bit crappy (showing their age).
    What can I replace them with ?
    Also there is a bit of room (perhaps) in the top corners of the roof either side of the windscreen (I have removed the roof lining). Would there be any benefit in purchasing a set of splits (main speakers in usual place, and the 'minis' in this spot ?).
    What can people recommend ?
    (I'd prefer to buy reasonable quality at a reasonable price - NOT top end stuff - it's a Defender after all).
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    I have the speakers in mine, in the headlining next to the front seat headrests. (one each side)
    I have pioneer speaker (probably middle of the road) (Head unit is good though)
    With the speakers anywhere else I cannot hear anything clearly.
    Bracken Ridge, Qld
    I have a Pioneer head unit to go in. How are the speakers mounted in yours ? Don;t spose you have nay pics of the instal ?
    gone
    1996 Discovery 1
    current
    will get one for you.... hang on... Mmmm appear to have lost my garage keys.... mmm great...
    Here you go:
    Bracken Ridge, Qld
    Nice, thanks.
    Whats it mounted to behind the trim. Is it in a speaker box ?
    gone
    1996 Discovery 1
    current
    Its just mounted to the headlining. The screws go into little metal clips.
    its actually a LR dealer fitment from new.
    Jun 2008
    pioneer and VDO dayton make a 4inch split kit, about $100
    in the defender you need 2 things - you want to increase the volume to hear it over the engine and road noise, and with the factory speaker mounts, you want to raise the level of the treble so you get some direction in the front.
    4inch splits in the front - mount the bass driver in the factory location towards your feet and put the tweeter drivers up on the dashboard. Pioneer TS-C1002 i think the model number is. These wire straight into most normal headunits and dont need a power amp.
    For the rear i would suggest some good 6inch speakers mounted in boxes up the back of the car (above the small windows either side of the rear door. there is room to mount the standard 6inch speaker boxes you would get from somewhere like JB or strathfield.
    if you want to actually get decent sound, adding one of the pre-fab subwoofer enclosures which includes the amp will bring up the bass which the deefie is always going to be lacking because there are no real cavities to fire a speaker into to give you decent bass (like a door or a boot).
    most newish headunits will produce enough sound to make listening pretty good at 100km/hr although adding the subwoofer makes a nice difference...
    Andrew
    Bracken Ridge, Qld
    Rear speakers could be more difficult than that - it's a 130 twin cab and speakers in top corners could be head-bumpers for taller passengers on rough terrain ?
    In my old single cab ute i had speakers mounted in boxes behind the doors (ire just in fron of bulkhead) and facing sideways (there were no front speakers). This seemed to work "OK".
    gone
    1996 Discovery 1
    current
    Central Queensland
    for entry level stuff, i'd go pioneer, nothing else, and try to find room for a set of 6.5" splits
