stand by for a sledging war on this one....
yes you can do it BUT.....
get it wrong and bad things happen.
I bat for the dont do it side of the fence mainly becuase Its very easy to get wrong which you will get away with once or twice (or 30 times) but then that one time you desperately need it to go right and you get it wrong and youve had it. Ive also read of cases (seen one) where the person trying it out pooched it got nuetral, paniced and lost control of the vehicle how bad that can get depends on all the factors that are against you at the time.
I reccomend that if you can work it up to the top of the hill in low range stop at the top or a crest midway and then go again in high range.
that said... heres how to do it without a double clutch (as per the book)
get it moving in first low, grab second.
get to a nice cruisey speed for second low ( 5-8kph is usually enough)
clutch in
put the tcase in nuetral
put the main box in nuetral
put the tcase in high
put the main box in first
release the clutch
back on the noise
this will result in some clunking of the tcase and IMHO does a little damage every single time you do it BUT it does less damage than screwing a double clutch shift like Im about to describe (side note a variation of this will let you do a lo-hi in an auto)
heres how to do it by double clutching (ask someone with a IIA or earlier main gearbox to teach you this and let you practice changing into second gear to perfect this) this whole sequence takes a bit over a second to do
take off in first low and work the speed up to where your engine is well over peak torque RPMS
clutch in
select nuetral on the tcase
clutch out
let the engine revs die off to about where they would be for first gear high range at the speed the vehicle will be doing in about a seconds time
clutch in
select high on the tcase
clutch out
get it right and you do no damage
get it a little wrong in the rev matching part and it either wont go in (and grind a lot) or it will clack a little and then go in (doing about the same amount of damage as the no double clutch change described above)
BUT brain fart the sequence or ride the clutch or totally pooch the rev match and you can kill a tcase in one go.(probabley not a new one, more likely on a high K's box)
heres the short version of that and you can do this one in less than a second
get it right and like the double declutch and youve got no problems get it wrong and you dont get the option of a little clacking its straight to damage for you.
move off in first low as per the double declutch
lift off of the accelerator and then at the same time select tcase nuetral
as the engine revs drop to the speed for first gear high range push in the clutch and as soon as its on the floor select high range (this should feel like one combined movement when you get it perfect)
ease up on the clutch and down on the accelerator, catch the friction point like you would for a normal hill start and keep driving
Im not going to describe how to snap shift it...
