Results 1 to 10 of 16
Thread: Handy Part Numbers
    Handy Part Numbers
    Morning all,
    For all those that like to tinker with your beasts, i will post this thread & during the course of working/playing with these wonderful creatures myself i will post part numbers that are hard to find yet are needed.
    Also for users who dont have a parts catalogue.
    • BOSCH BBA550 - Wiper Blade Replacement - are an EXACT replacement for the factory blade. Available from Burson's, Repco & other Bosch stockists. Should take about 6 seconds to replace each blade
    • 4H2Q-9K546-AE Siemens original part No
    • 4H2Q-9K546-AF Siemens upgraded part No, supplied as replacement for above.
    • DMB500040 - Window washer reservoir
    • DYR500010 - Clip cover. The clips on the front & rear tow covers that may crack occasionally.
    • FFY500020 - Glove Box retaining pin
    • FYC500040- Trim clip. The little silver ones that break everytime you take the under tray off from under steering wheel, or when u remove the centre console tower.
    • LR005961 Land Rover refurbished exchange diesel injector kit
    • LR008052 - LED replacement rear lights if you are feeling wealthy
    • VUB502860 - Fitting/Mounting kit for Driving Light Switch. Includes templates & instructions to mount the below part number.
    • XKB500080 - Driving Light Switch. Usually need both parts to install switch.
    • XPD500790 - Audio Steering Wheel Switch set. 07my+ only
      __________________
    Queensland
    G’day sniegy, great idea and here’s one that needs a name as well as a part number.
    The lock in clips that hold the front recovery hitch cover and the rear tow hitch covers in place.
    Twist them the wrong way and they are busted!
    Hi Drivesafe,
    Yes i will get them also.
    I will post all the part numbers in the original post, that will stop everyone trawling through the post to find numbers that they may be after..
    FYC500040 - Trim clip. The little silver ones that break everytime you take the under tray off from under steering wheel, or when u remove the centre console tower.
    DYR500010 - Clip cover. The clips on the front & rear tow covers that may crack ocassionally.
    VUB502860 - Fitting/Mounting kit for Driving Lght Switch. Includes templates & instructions to mount the below part number.
    p.s. cant continually add to the original post. Will cut/paste to keep all parts together.
    Cardup, West Aust
    Quote Originally Posted by sniegy View Post
    Cameron
    If in doubt, throttle out
    MY16 RRS SE SDv6
    MY16 Ranger XLT
    2008 911 GT2 - dream came true
    1976 Escort mk2 - race car
    DMB500040 - Window washer reservoir.
    FFY500020 - Glove Box retaining pin.
    Jan 2009
    In the interest of keeping things together, found this wiper blade info on one of sniegy's earlier posts.
    Cardup, West Aust
    Bump...... in case anyone has something to add to the list. Perhaps the iPod lead or the steering wheel audio controls.
    Cameron
    MY16 RRS SE SDv6
    MY16 Ranger XLT
    XPD500790 - Audio Steering Wheel Switch set. 07my+ only.
    Quote Originally Posted by Brick View Post
    Hi Cameron,
    The Ipod lead is not a factory part number.
    (If u have an HSE in the rear of the centre console is a 3.5mm Auxilary jack & all u need is a 3.5mm to 3.5mm stereo lead-plug one side into the Ipod & the other into the Jack & away u go. The only thing this doesnt do is charge the Ipod)
    I would normally buy a special lead in & retro fit them to a customers vehicle if required.
    This will charge & play from an Apple Ipod throught the factory unit..
    This will NOT work for an Apple Iphone though, it has a different charging system & retailers are working on a new lead etc.
    LR does have an Ipod adaptor kit which gives you a holder, charger, USB port & in/out connections. Kit is expensive though but works well.
    I have added the S/wheel Audio control to the above post for all to see.
