Results 1 to 9 of 9
Thread: Defender aircon smelling like a dead rat!
    Jun 2008
    Manning WA
    Hi, Hot day in Perth (35 degrees) anyhow put the aircon on air cold but with an awful smell like somthing as died . Any ideas
    Cheers Stewart
    d@rk51d3 Guest
    I think you've probably answered you own question.
    The smell won't leave in a hurry either.
    Is not Rat... is Siberian Hampster!!
    Seriously I've heard of other cars that develop smelly A/C due to small leaves sitting in the system.
     2005 Defender 110 
    JohnR Guest
    Is it a Puma?? Cause mine does that when I turn the Air-con off ? It's been to the dealers several times and they keep spraying smelly stuff down the vents but that only works for a day Ther're excuse is that to get to the suspected offending part they have to rip half the car apart and they are too big a sooks to do that
    solmanic's Avatar
    solmanic is offline One Merc post away from being banned...
    Maleny, Queensland
    It may be cat p!ss. Cats often go on plugs or vents or anything like that. I used to have problems years ago when one of our cats kept going to the toilet down my car's air vents. The air intake on a Defender is an easy place for them to use since it is on a nice flat surface.
    Quote Originally Posted by solmanic View Post
    I like cats even less now.
    Jun 2008
    Manning WA
    Took the top and side grill off my 200tdi, had a look inside could not smell anything , I have noticed that after ten mins the smell goes away ( or I get used to it ) .
    Will getting the aircon re-gased help ?
    Ocean Reef WA
    Aircon smell.
    Sounds like what happened at Home Valley Station a year ago. The Cook and I went off down to the Pentecost R. to watch the others fishing and the station manager asked if I had a screwdriver and I did and lent it to him. 10 minutes later he had his answer to the rotten stink..... a dead mouse!
    It nearly made them all puke when he turned the aircon on although it couldn't have been dead that long as it hadn't stunk the day before.
    I used to think all Tojos smelt like that but mustn't say that now as I've got one as well as the Defender!!!
    Happy sniffing.
    Alan.
    in the wild New England, NSW
    check the drain hose....
    run heavy insulated electrical wire through it like a cleaning rod
    if it's blocked with leaves etc they will decompose and smell like....
    ............or have an aircon guy clean it out for you
