Thread: hydraulic pump
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    hydraulic pump
    anyone have the specs on the hydraulic pump on a 4db1 used for the power steering?
    can you use or do you need to get an up rated pump to run a winch motor ?
    pondering............
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    you can use it to power up a hydraulic winch but it doesnt really make the grade flow wise you will also want to fit a cooler and larger fluid resivior...
    ask nice I might just happen to have sitting on the back of one of the moweres Ive aquired to pinch hudraulic bits off of a suitable belt drive pump.
    Feb 2005
    a mate of mine runs his hydraulic winch off his power steering, the down side is when you move the steering wheel the winching process slows down untl you unload the steering valve thingy
    Theoretical delivery 12.2 cc/rev (0.732 in3/rev). 8 litre/min (1.8 imp gal/min) at 200 rpm
    Relief valve setting 85 kg/cm2 (1208 psi)
    operating speed 450 to 4000 rpm
    pump to crankshaft ratio 0.89 (25/28)
    mcrover Guest
    Yep, should be fine
