Results 1 to 9 of 9
Thread: Can Link Error
    Nov 2008
    on the move
    Can Link Error
    Anybody know what this means, all the codes were cleared from the ECU but Can Link Error returned straight after.
    Car is running fine, should I worry about this code?
    Sorted out the electric fan issue when all the codes were cleared.
    Could this can link eror have anything to do with fitting a new battery and disconecting the battery power or alternatly having a new CD player fitted?
    Jul 2007
    Pilbara
    What diagnostic equip are you using? CAN link error can be related to the diagnostic equipment/software not being fully compatable with the TD5 and is a diagnostic equipment error code not a Land Rover code. Some vehicles use a CANbus system the TD5 doesnt so a communication error comes up.
    May be your problem.
    Rick
    Nov 2008
    on the move
    I have no idea what type of diagnostic equipment their using but as they are a specialized Rover workshop I would imagine they have the correct tool.
    Seeing as the car is running fine, I'm not concerned, might be a glitch on their side.
    Thanks for the input.
    Ellendale Tasmania.
    A CAN error is a communications fault between the ECU and whatever may be faulty, it comes up a lot if there has been faults recorded, oil in the injector harness and MAF faults usually trigger it on most occasions.
    TD5s do have CAN BUS as well.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Jul 2007
    Pilbara
    OK I stand corrected. I just Googled canbus and now know less than I did before. I have had similar errors come up on diagnostic equipment used on heavy earthmoving equipment and it is usually a communication problem. The software i am used to will identify if there is a communication problem, either input or output, between a sensor and a controller and log a seperate error. I have had later versions of software bring a similar error up on older machines because it is searching for a CAN system that is not there. Bring back the days when there was no monitoring, we could reduce breakdowns by 90%, but the other 10% would probably be terminal.
    Rick.
    Nov 2008
    on the move
    Soooooooooooooooooo?
    As I have had the injector loom replaced as it had oil in it, could there be still some oil in the ecu side of the plug causing this code.
    As the car seems to be running fine, should I not worry about and just drive it?
    Can Bus?????????
    Whats that?
    Please excuse my ignorance.
    I'm starting to think my Italian motorcycle is not so complex any more
    Thanks for the replies.
    Jul 2007
    Pilbara
    Quote Originally Posted by Gold_TD5 View Post
    Are you saying Italians are not complex people, the hand signals most of my Italian friends produce are not simple.
    In simple terms a CAN system (Controller area network) is a way for sensors and switches to provide information inputs with a controller and the controller to provide outputs to sensors or other controllers without having complex computers everywhere. It reduces bulky wiring harnesses and such. You can have, say 5 sensors providing inputs, one will say I think I have a problem, another may say I know I have a problem and a third may say I have a problem and it is terminal. The other sensors in the system if related will be saying, nah we're all right. This third fault will take priority and may shut down the engine or drop it back to idle. The second fault may cause a controller to adjust fuel input or similar. All faults should still be logged. Some systems I am used to have a number of digital inputs and outputs from a number of sensors all on one wire which makes faults a little harder to diagnose.
    May 2003
    On The Road
    The TD5 is mechanically simple,, its just a diesel after all.
    The electronics are amazing though.
    A MUCH maligned and under-appreciated piece of LR engineering.
    Nov 2008
    on the move
    So, I drive it till it stops and hope it's not inconvenient?
    Then hope I can identify whats gone wrong.
    Sounds like I am going to need a Nanocom, or whatever it's called.
    Seeing as the car is running great, could this just be a dirty/loose conection?
