Results 1 to 4 of 4
Thread: turbo for td4
    hmidet Guest
    turbo for td4
    there is three days ago i find some oil on turbo of my freelander td4 but in this day when am coming to my home i listen a new sound came from the engine and when I edge the engine I found that the engine oil output is any smoking that want to know why the turbo and breaks thank you
    Turbos like all mechanical things can simply wear out when they reach the end of their service life.
    However I would have thought that unlikely for most TD4s. Premature failure is mostly caused by some sort of oil stavation, a metallurgical failure of the turbine or a physical failure caused by sucking in something.
    You indicate there is an oil issue and some noise - but what makes you think the turbo has actually failed?
    hmidet Guest
    Post thank you
    hello and Thank you for advice and assistance and security that this problem has gone and I'm now going to change the turbo and I hope that this is the last fault affects the vehicle and thank you very much for assistance and I hope to always be well happy day
    Premature EOL of a turbo can also be driving style...
    More down to lack of spool down time (idle down) after driving -you should idle down for 10 sec min or longer if you've been working the engine hard.
    Also important is warm up time, drive gently until up to full operating temperature before going for full boost use.
    Also, good quality oil and regular changes of oil and filters are important.
    Where are you from?
