P38A diff in Defender
Does anyone know for sure if a rear P38A diff head (1998 so presume 4 pin) will fit in the front of my 1995 24 spline Defender? Just thought it might be a bit of an up grade that would bolt straight in. I am assuming (oh-oh
) that the physical size, bolt pattern and ratio's are the same. Thanks in advance........jim.b.
1995 Defender 110 300TDI :D
1954 86" Series 1 Automatic :eek:
Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
