23rd December 2008, 09:22 PM
Traxside SC80
Hi there, just wonder if anyone has used an SC80 for duel battery, winch application off the axuilliary battery. If so did you simply use the traxide wiring diagram for winch applications utilazing a marine battery switch but simply wiring the winch into the auxilliary battery??
I ask because my understanding is that the SC80 wouldn't isolate the cranking battery and if i use the marine battery switch to eliminate the paralell circuit i infact isolate the alternator and so get no charge into the axilliary. Am i on the right track or am i all confused here,
am thinking i am confused.
Please help, oh and if you read this Tim i have sent you another email asking for more help, cheers
23rd December 2008, 09:27 PM
Im sure drivesafe the maker of this fine equipment will be along soon to comment , If not pm the man he will gladly answer your questions
25th December 2008, 12:06 PM
I wired in an SC80 a few months ago with a Marine Switch.
The switch when in the on position parallels the Cranking and Deep Cycle batteries together.
My winch power cables are connected to the deep cycle battery, not that it makes any difference when the batteries are in parallel
