Thread: EFI ECU Relocation
    Adelaide - Torrens Park
    EFI ECU Relocation
    Here is the end result of another little job I have done in the past month.
    It only took an hour or so and will help prevent ECU failure if (when) I get water inside.
    mike 90 RR Guest
    Well done
    ... I see that no one has solved the loss of the air vent tho
    I have got the hose pointing at the vent. Air still comes through, just not quite as much. Of course, there wasn't much coming out of that vent to start with...
    Do the computers get hot at all, just wondering why you couldn't place the computer in an air/water tight electrical box and leave it under the seat.
    Just thoughts as I to have to fix this before I drown it.
    84 Alfetta GTV
    Douglas Park, NSW
    Quote Originally Posted by GuyG View Post
    This is what I've done with mine. I checked for heat for the first few weeks & all seemed OK.
    It's now been sealed for at least 2 years without a problem.
