Chris,
There is quite a bit more involved with the 200Tdi to ZF. They weren't available here in OZ in the RRC or early D1, the adapter plate etc from the 300Tdi to ZF won't fit and the engine is offset in the 200Tdi defender more than the 300Tdi is, and the floor pan and seat box is different to the MA series 1994 onward 300Tdi etc (Not that is really an issue with an auto conversion)
You CAN do it, as Simon says the shafts etc will end up in the same place and it would be easy to find plenty of room for the cooler etc... it is just a whole lot easier to use a 300Tdi 1994 onward Defender... I have done 2 of those and they are a great result as I used a complete Donor Disco for one of the conversions.
JC
