Results 1 to 6 of 6
Thread: Different dia spares
    Aug 2008
    Sunshinecoast QLD
    HI, I was wondering if anyone knows of any problems I might have with tyre diameter of my spares ( wanglers 763mm ), being used with larger diameter(LTZ 799mm) on the car.
    Cheers Ken
    Nov 2007
    You might find your traction control kicking in very early. Only way to know is to put em on and try.
    I wouldnt be trying it. (especially in something as complex as a D3) It may well cause transmission wind up or worse.
    The larger tyre has a rolling diamater of 2510mm
    the smaller has a rolling diamater of 2397mm
    So in 1 KM the larger one will spin 398.4 times
    The smaller one will spin 417 times.
    Thats quite a big difference...
    Adelaide - Torrens Park
    If you have air suspension you will log fault codes and possibly cause limp home mode to come on.
    Sydney, Australia
    I suppose it depends how far you drive with it on and whether it is on tar.
    Douglas Park, NSW
    Don't risk it. As BigJon says, it can cause suspension problems (and all sorts of other strange faults that can have repairers scratching their heads).
