Results 1 to 10 of 27
Thread: Waste Gate
    SA, Newton
    Waste Gate
    Waste Gate
    I am looking for an external waste gate, Not a blow off valve. that will spill hot back in to the dump pipe. i need just over 3.50 cm2.
    it will also need to be ajustable, but should be able to mod anything.
    Padstow NSW
    yes and?
    cheers phil
    Quote Originally Posted by clean32 View Post
    Waste Gate
    which means what exactly?
    hint -
    inches would be nice
    Safe Travels
    harry
    here
    you running a standard computer or aftermarket? What brand and model?
    These are good - google for ED wastegate.
    SA, Newton
    Quote Originally Posted by harry View Post
    hint -
    There is only 1 thing I have in inches, and I will not post that, because it will send you along the path of depression then Prozac.
    SA, Newton
    Quote Originally Posted by Bush65 View Post
    yes but big ugly and vent, i realy need to bypass back into the dump pipe,
    what you have posted looks like a over boost thingy.
    SA, Newton
    Quote Originally Posted by catch-22 View Post
    ha ha ha ha
    SA, Newton
    Come on guys im being serious here. if I have a .32 AR sitting in front of a .65 AR, I need some way of getting the large volume of gas around the .32AR very important, more so if the .65 waste gate ever opens, I don’t want massive over run and a small shrapnel producing device under the bonnet, the ,32AR waste gate gives only 1.34 cm2 I need in total about 4.5 cm2
    here
    I have never known a wastegate to be measured in A/R....
