Results 1 to 4 of 4
Thread: No Reversing Lights..!!
    Mar 2007
    Newcastle NSW
    A work colleague just purchased a 2000 model V6 Auto..
    Came to me yesterday complaining of "no reversing lights". Reckoned that he had checked the globes and they appeared OK. I pulled Fuse 2 and checked it with a multimeter and it is good....
    I will remove the globes today and double check them with the meter.
    If these are OK, it looks like it may be the switch, broken wire, bad earth etc.
    Can anyone advise me where the reversing switch is located. Is it attached to the gearbox, or part of the T-Bar assembly.......???
    Nov 2008
    Maudsland, QLD
    I have a copy of the RAVE manual - BUT - its on my other laptop....
    If you dont have an answer by the time i get home i'll have a look.
    Mar 2007
    Newcastle NSW
    Quote Originally Posted by mjm295 View Post
    My Rave doesn't seem to cover the V6...
    Been scouring the Electronic Parts Catalog...no luck there either...
    Any help will be greatly appreciated....
    Dandenong Ranges - Victoria
    A few words from the RAVE CD.
    Reverse
    When reverse gear is selected, a main relay feed is able to flow from the transmission
    selector/inhibit switch (C0244) to the reverse lamp relay (C0935) on an NG wire. The
    reverse lamp relay (C0935) is earthed on a B wire and controls operation of the reverse
    lamps. For more information on reverse lamp operation, refer to the Brake and Reverse
    Lamps section of this manual.
    +BRAKE AND REVERSE LAMPS.
    A main relay feed is also supplied to the ATCU (C0932) and the selector indicator (C0675)
    on NG wires. The 'R' symbol on the selector housing will now illuminate.
    Automatic Transmission
    Fuse 2 of the passenger compartment fuse box (C0580) provides an ignition feed to the
    reverse lamp relay (C0935) on a G wire. When reverse gear is selected, the Electronic
    Automatic Transmission (EAT) ECU (C0932) provides a feed to the reverse lamp relay coil
    (C0935) a feed on an NG wire. The relay coil (C0935) is earthed on a B wire. The energised
    reverse lamp relay (C0935) is now able to provide a feed to the RH (C0455) and LH (C0472)
    reverse lamps on GN wires. Both lamps are earthed on B wires.
    So check that the reverse lamp relay is working next.
