Results 1 to 10 of 23
Thread: 2 interesting things i found out about the p38
    Nov 2006
    narellan, sydney
    1, the seats have heaters inside them, but they are not hooked up (the wires are there)
    2, The diffs spin in the opposite direction, due to the viscous transfer which works like a limited slip diff (unlike a conventional constant AWD transfer that acts like an open diff). So this is the reason that the front and rear centers are not interchangable.
    Ok, that doesnt sound right, the diffs do turn in the same direction, but the crownwheels are on the same side, where they are normally on the opposite. The tailshafts turn in the same direction, whereas they normally turn in the opposite direction.....confused? ok i'll shut up.
    Andy
    urmmm...
    the crown wheels would need to be on the opposite sides and the shafts would have to counter rotate for it to be anything unusual.
    Douglas Park, NSW
    Thanks Andy. I didn't know about the seat heaters but some D2s (with leather) have the elements already in place too.
    Interesting about the diffs too. I have seen the later Defender diff (Rover type) referred to as a P38 diff. Does this mean that the Defender is similar? Or is it the front diff oin the P38 that's skew-wiff?
    Douglas Park, NSW
    I thought Andy was trying to say that both crownwheels are on (say) the N/S & therefore are on the opposite sides when the centres are compared side by side.
    Nov 2006
    narellan, sydney
    urmmm...
    OK i am wrong. I got very confused
    but hey atleast the seats DO have heaters (HSEs anyway)
    I think what your getting at is that if with all the wheels off of the ground and you grab the rear prop shaft then turn it that the front shaft will counter rotate but as you have the VC the front shaft turns in the same direction
    Nov 2006
    narellan, sydney
    correct, this is what i was trying to say, but blacknight has me seccond guessing myself now. I am going to have a better look on monday.
    my monies being on the diffs being the same (crown wheels on left hand and right hand side of the vehicle) with the propshafts rotating in the same direction.
    the only time Ive ever seen counter rotating shafts is on some trucks that use a direct gear drive to get front output, same concept in gear drive as a normal transfer case but instead of driving a diff the rear output is always driven and the front out put is a dog engagement on a gear that hangs from the rear output gear.
    4.1 R&P P38
    sorry wrong section
    Jeff
    Coogee, South of Fremantle, WA
    Not sure the exact models years but having recently found out late defender 130`s have exactly the same diff as the p38. They could also be optioned on the 90`s
