Results 1 to 10 of 23
Thread: another towing thread
    sunny Hobart
    Question another towing thread
    guys, after some experienced opinions
    WHAT TOWS THE BEST (ie maintains highway speeds, doesnt get hot and anything else towing related)
    1. Td5 auto
    2. Td5 manual
    3. 300 Tdi manual
    4. 300 Tdi auto
    max load would be a heavy camper trailer and the 4x4 loaded to the hilt (which isnt that much in a D1)
    thanks in advance
    Yass NSW
    I always thought that my 300TDI was a better tow vehicle than my TD5 Disco. The TDI would pull a loaded car trailer just about anywhere in fifth and felt more stable probably because of the shorter rear overhang.
    The trade off was that the TD5 was a much nicer vehicle to drive at highway speeds without the trailer.
    Regards,
    Tote
    Free Again Thanks Dan
    Quote Originally Posted by shorty View Post
    1. Td5 auto
    2. Td5 manual
    3. 300 Tdi manual
    4. 300 Tdi auto
    thanks in advance
    Count the Tdi ,s out ,They will tow heavy weights but will need either low range or clutch slip to get going with the manual ,i have towed a 6 ton mitsu 4x4 camper truck with my Tdi very slowly
    Now that i own a manual Td5 i wont be going back
    depending on how you like to drive.....
    assuming all is stock the td5 manual has my first vote... so Id order it
    td5m
    td5a
    tdim
    tdia
    rejigging the tdi would get you
    td5m
    tdim
    td5a
    tdia
    and then of course you can work up the td5 which puts you back in the first order.
    there is of course the argument that the auto does a better job of towing but that is a personal thing and you have to weigh off the advantage of being able to hold a little more speed on the hills because of the torque converter doing its thing and not having to worry about gear changes against the slightly higher initial cost (assuming you buy new), the heat loading of an auto and the slightly lower fuel economy.
    sunny Hobart
    td5m
    td5a
    tdim
    tdia
    td5m
    tdim
    td5a
    tdia
    I like to be able to cruise at 95klm/hr on the open road. That speed makes for comfortable cruising at respectable fuel economy and doesnt create too much of a queue behind you.
    As for jigging the 300tdi, do you mean things like exhaust, upgraded intercooler etc as they dont have a 'puter do they. The Td5 would just require an ecu upgrade and exhaust at the min to get any extra power out of it??
    thanks and keep the opinions coming.....
    sunny Hobart
    oh, BTW, was there any power/torque differences btn the 99 and 04 Td5's
    Brisbane, Inner East.
    A 4BD1T
    URSUSMAJOR
    sunny Hobart
    Quote Originally Posted by Brian Hjelm View Post
    A 4BD1T
    yes, that would be nice but unlikely
    No. The other advantage of a post 2002 Td5 is the ECU can be remapped without having to be exchanged.
    sunny Hobart
    Talking
    ta
    I have also been told to get a 03 or 04 model. I think it was refered to as the update model as it has the CDL.
    any other pro's for a late model one?? other than mileage and condition
