Thread: Pics of timing belt change
    Western Australia
    Pedro, because you asked most succinctly....
    With cover off
    Tool kit ready
    Seriously
    Don't forget to protect turbo inlet from foreign matter
    thermatic fan off
    EGR throttle inlet removed
    There's the belt
    The two idler pulleys, note the rubber crumbs, I assume they came from the belt but no obvious signs where
    The tensioner pulley
    Close up of tensioner
    LH camshaft sprocket
    Ooooppppps, some lamp work jewelery SWMBO makes
    RichardK
    Series IV Matrix Offroad Camper following our Discovery 3 with E Diff, BAS Remap, Mitch Hitch, Uniden UHF, Codan NGT HF, Masten TPMS, Proquip Compressor Guard, ARB Winch Bar, Milemarker Hydraulic Winch, 4x4 Intelligence Rear Wheel Carrier, VMS GPS with Rear Camera,
    Adelaide - Torrens Park
    Did you do the fuel pump drive belt?
    Western Australia
    No, I have the kit and will do that in the next two weeks
    RichardK
    Nanny state UK...
    A picture is worth a thousand words.
    BTW - Those rubber crumbs probably appeared when you broke the sean on the timing cover.
    M
    Jan 2008
    Lysterfield, VIC
    that looks scary.....the engine looks easy though.....nah seriously, well done, looks scary to do!!!!
    Dave.
    Hi.
    96 Disco 1 V8.
    99 Disco 2 TD5.
    LROCV.
    Up a hill in the deer park
    Thumbs up
    Excellent photographs Richard.
    Thanks for posting them
    Western Australia
    Quote Originally Posted by camel_landy View Post
    M
    Hi Mark,
    I don't think they were from the timing cover seal, that seems more like a PVC compound and the bits were more rubber compound
    RichardK
    hzwart Guest
    HP belt change
    Hi Richardk
    Do you have the photo's of changing the HP fuel pump?
    Thank you
    Western Australia
    Hi hzwart,
    No, I didn't do it before I traded it for a new D3, I do have a complete set of instructions though, if you PM me I will send them if you want them
    RichardK
    those rubber bits are from the sides of the teeth on the belt.
    you can quite clearly see the roughing of the edges in the pic of the idler and the cam gear. this happens because of the rubber hardening and then trying to flex.
    Its a bit like the cracking that can turn up in suspension bushes or on the edges of the tread blocks of an old unused tyre that gets pressed into servive.
