Results 1 to 10 of 12
Thread: what am i missing ????
    Perth W.A.
    hi guys.
    Am trying to remove the front hub to change out discs and pads cant get the flange nut to move what am i doing wrong any help appreciated
    Feb 2005
    have you straighten the lock washer tab
    the outer nut can be very tight, depend on how heavy fisted they were
    Perth W.A.
    the outer nut is a complete nightmare have only got mulgrips at hand too ?!?
    Feb 2005
    cold chisel/big screw driver and hammer is the rough way to do it
    anti-clockwise
    Perth W.A.
    do you need to put the dif lock on whilst beating the seven bells out of the centre nut and does anyone know if rovercraft do the land rover spanner that is supossed to remove the bloody thing
    Rovercraft should sell it. If not Roverparts in Victoria definitely do.
    If you're handy with a welder then just weld two tabs to a piece of square tube and drill a hole for a bar to fit through. Mates been using one like this for years.
    May 2008
    Horsley Park, Sydney
    Hi, I am not sure what vehicle you have, but of it is later than 1999 then there is a single nut with an attached locking tab on the nut. This will have been flattened against the flat on the drive hub to stop it from undoing.
    You will have to relieve this by driving a screwdriver or similar between the nut and the flat of the hub to allow you to undo the nut. These are normal right hand direction thread.
    Erich.
    Quote Originally Posted by Bundalene View Post
    Erich.
    ... and done up to a mere 490Nm. So use a big pry bar!
    Perth W.A.
    430 of the best never move !!!
    my motor is a 130 tdi 1998
    I get the idea of a tab to make a pseudo spanner with a mean old bar going through it sounds like choice idea may well be an option ( my mate is a boiler maker ) don't know i should worry about the brakes for the roadworthy but, they only have a bit of fade on them i am just noticing now, the big drama is the bloody oil leaks that will give me a heart attack one is easy sump gasket, the other is the transfer box, jordon rovertech were supossed to have done the intermediate oil seal before i bought the motor rang them today and they reckon its possible to do that and not notice the shaft has ovaled allowing the oil leak (possible? ) i don't know all i know is, it's another drama
    Perth W.A.
    Erich.
    right handed to undo or do up ?????
