Results 1 to 10 of 13
Thread: oil pump bolt
    Ean Austral Guest
    Cool oil pump bolt
    Gday, hope im in the right forum as only new to this.Have read a few threads about the oil pump bolt in td5 disco.I havent heard of this problem before mine has 200k and not been touched.Is it time to panick?
    Nov 2007
    home at last - Port Macquarie NSW
    just got my car back today from service. its a 2002 TD5 Disco 2. oil pump bolt was not loctited and was not very tight at all according to mechanic. guess that was money well spent getting it checked.
    May 2003
    On The Road
    a VERY well known problem,,
    some have it, (loctite) some dont,,
    just 2 minutes ago on our Tech Forum--
    Oil pump bolt
    Search is your Friend,,
    But do it.
    Do it NOW!
    Ean Austral Guest
    Wink oil pump bolt
    Thanks for the replys,is it as simple as loctite the existing bolt or or they replacing the bolt.I guess it you go that far you should use a new bolt.I assume its the bolt holding the drive cog on the pump?
    Thanks.
    South Yundreup,WA.
    Normally it is just a matter of loctiting it back in as it just comes loose and there is no damage to the threads. When removing you would have to check it for damage to the thread. They are not single use bolts like the head bolts.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Yass NSW
    Yep you can reuse the bolt unless damage has already begun to hapen.
    I was even able to reuse the sump gasket. Replaced the gasket 1 months later when doing other work.
    fairly easy job to do and worth the peace of mind.
    Nov 2007
    new bolt is less than $5 and is pre loctited. i wouldnt waste the time taking it apart without replacing that bolt as it is so important
    Ean Austral Guest
    Thanks for the replys,The only reason I asked was its impossible to get anything for landrovers in Darwin, cant even get a sump gasket from the so called dealer so I bring everything up from south. So if you pay for a 3kg airbag you may as well fill it,am fitting new shockies and fixing an oil leak behind the turbo tommorow so will drop the sump and check it,got some gasket goo until I get a new gasket.
    Cheers Ean
    Oct 2008
    Interesting - How is the bolt pre loctited, I've not seen one of those before - Any pictures?
    Ean Austral Guest
    Red face
    Was going to ask the same.BUT..
