Can't help with the question Brenden, but when will you be here next?
I'll be touring the country from late June to the end of September this year.
Discussions about doing the CSR on return to Australia are going on. Yep we will do it in your winter months.
Have had a quick look at Oz explorer and see that they say fuel consumption for a 4 cylinder diesel is 309 litre for the 1961 km route. That equates to almost 16l/100km for the entire trip. My worst fuel consumption in last years trip was 17l/100km (across the Simpson after a sand storm) whilst my average over 40,000 km was 10.8l/100km
What fuel consumption would you expect for a 300TDi 110 on the CSR?
Is a 160l fuel capacity (standard 110 tank + wing tank +40l in jerry cans)sufficient to do the CSR without arranging a fuel drop?
What is minimum fuel capacity recommended for a 300Tdi 110 for the CSR?
Brendan
All the guide books/reports I've ever seen have recommended a minimum of 300l + fuel drop. Availability of fuel these days I think has negated the old fuel dump at Well 23.
As I haven't done this run, others will give a better indication.
FWIW, on our Madigan Line trip last year, our trip out to Geosurveys Hill resulted in horendous consumption (Td5 Defender), so be prepared!!!
Numpty
Betsy - 1963 Series 11A ex Mil GS
REMLR No 143
If you've averaged 17l/100km in the Simpson and your overall average is 10.8l/100km overall..... I really don't think that you'll be getting 8.16l/100km and assuming that you can extract every last drop of fuel and arrive bone dry with the tanks.
I'd be allowing for 17l/100lm + reserve + 20litres left in the tank.
Slunnie
I have averaged about 13ltrs for my Tdi through the simpson and surrounds but I would take slunnies advice and go 17.Which way are you going?,from the top down or bottom up?.Can I tag along for a couple of days?. Pat
Hi There,I did from Wiluna to well 23 fuel dump in 2000 and we averaged 15.5l in a 300tdi disco.It was fully loaded 3 people plus all our gear.I know you can get fuel at well 33 (aboringinal community) and there is also a community at the northern end that you can sometimes get fuel. I know the names and contact numbers will be on the explore oz website.So with your fuel range you shouldn,t need to arrange fuel at the fuel dump.I am planning to do the trip myself next year.Watch out for the corrigations.
Cheers and enjoy Ean
Always better to plan to arrive with some reserve in your tank rather than suffering the inconvenience and embarrassment of being 100 or do K's short of your destination.
Roger
If I recall correctly, they don't do a fuel drop any more. You need to get your fuel from one of the communities.
You also need to get a permit from the national 4wd council
Brendan,
Shock absorbers, shock absorbers, shock absorbers. Be under NO illusions this is a very hard track on suspension. ESPECIALLY when loaded for the distance.
I know you have only just been out here, but this is probably a notch above the tracks you may have encountered both for its isolation and length. Being well prepared has never been more important.
(I'd love to come along though...)
JC
A friend spoke with capricorn roadhouse in newman and they will be doing the drop this year.The present quote was $500 per 200l drum but this will most proberly fluctuate weekly.
Cheers Ean
