Results 1 to 10 of 17
Thread: oil temp guage for ZF auto
    Who has installed a temp guage of the auto on their Range Rover? If you have where did you install the sender and what sort of temp does it run at normally?
    I was hoping their was a place for a screw in sender but I am thinking you might have to use an inline one.
    I was also just going to use a speco oil temp guage like I have for th engine oil temp but I was not sure of the running temp.
    Any other help or suggestions would be appreciated.
    thanks,
    Adam
    Yass NSW
    Not a rangie but mine is welded into the sump. First one was next to the drain plug. New sump has it in the flat side at the front. I haven't got the box above 50 deg since the rebuilt yet. Old one wis farenheight. I bought an actaul gearbox oil temp guage.
    Jan 2008
    BrisVegas
    Same. I silver soldered a brass fitting into the front of the sump next to the return line. temps get hot when towing and now gearbox is kaput...
    Ok. But does anyone have any other method. I would rather not remove the crossmember again to remove the sump. I still have to run the hoses up to a custom oil cooler on the back of the ute so I was hoping to be able to get an inline sender.
    Jan 2008
    BrisVegas
    silver solder a tee piece into the line and fit where you like. Preferable to use hot line.....from high side of oil pump.
    Thanks. I'll do that
    Avoca Beach
    x2.
    I guess the clue is that the standard temp switch on a RRC is in the circuit before the cooler.
    Regard sPhilip A
    Geelong, VIC
    IIRC somebody on this forum was using one of the TM2 temperature gauges to monitor their auto.
    Its a bolt on sensor so no need to break into the oil system - just monitor the temp of the case itself.
    Thanks Steve, but I would prefer to monitor the actual oil temp. The auto will be behind a 4.6 and pushing 35" tyres, mostly offroad so I reckon monitoring the oil temp ill be pretty important.
    I will also be running the oil cooler at the back of the cab (ute) with a thermo fan so I will want to know if the thermo fan stps working for any reason.
    Brisbane, Inner East.
    Does the trans have a dipstick? VDO made a temp gauge for this purpose. The sender was in the form of a dipstick and was slipped down the tube.
    URSUSMAJOR
