Results 1 to 9 of 9
Thread: Diesel Gas on New Inventors
    Aug 2008
    Hi, Can't seem to find a post already on this anywhere else, so here goes:
    The Gas Tek, diesel gas, sequent system, or any other name it goes by, is on the New Inventors on Wednesday (tomorrow) 11 Feb at 8pm on ABC1.
    This is the computer controlled diesel gas system with all the monitoring, coolant, EGT, etc.
    So what did people think?
    Were you convinced?
    Canberra, Australia
    Michael T
    2011 L322 Range Rover 4.4 TDV8 Vogue
    Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
    Jun 2008
    Sth East Sth Aust
    Looks interesting
    It looks interesting and plausable
    site DieselGas Sequent II
    would be interested if someone has tried this/ knows of an actual installation
    Nobby
    Safety Bay
    Dereck has had it on his vehicle for years,it does work. Pat
    There are a few blokes on here with the system fitted to their cars.
    Aug 2008
    The few people who have the system say it works well. More power, smoother idle, smoother through the gears, revs easier, less smoke etc.
    As yet I haven't really run across any bad experiences with this system.
    The show didn't really add too much more that couldn't already be found.
    A couple of small things though: waterproof to 1.5m and combustion efficiency improved from 78% to 99%.
    Noticed the discovery with a 300Tdi they were testing on, and a Defender with 300Tdi also. So 300Tdi should be well tested at least.
    Safety Bay
    Derecks own defender has the timing advanced,the fueling turned up,the boost is up,he runs twin intercoolers and gas.His engine has been worked very hard and hasn't caused problems.They are alot stronger than you think. Pat
    I went out last night so missed it. I can't get the segment to download from the ABC websit.
