Thread: front tow bar
    Adelaide
    Thumbs down front tow bar
    Hi
    Anyone put frount tow bar on a Disco with a bullbar. If so how much did it cost and how good was it getting things into tight spots
    All the best
    Ben
    Ben
    Disco 1997
    Divers do it deeper
    May 2003
    On The Road
    Are you looking at a haymanreese square tube type?
    at least then you can take the goose neck out and use it at both ends---
    Mar 2007
    South Arm, Tasmania
    I haven't got one on my Disco, but used to have one on the front of my old Rangie years ago when I also had a 30 foot triaxle caravan. The tow hitch was not central on the front - it was offset to the left (passengers side) so that when moving the caravan, I was looking along the left side of the caravan and could easily see its full length and the tip of the rear bumper bar. Made moving the caravan into tight spots much easier.
    As Pedro has said - use the Hayman Reese style hitch so that a single tongue can be used both ends.
    Another good possibility with this, assuming the front tow hitch is securely connected to the chassis - I use a "billet" with D shackle which slides into the rear Hayman Reese hitch in place of the towing tongue as my rear recovery point. With a Hayman Reese style hitch on the front as well, the same style of recovery point could also be used here.
    Cheers .........
    BMKAL
    Ouch
    Medowie N.S.W
    Do you have airbags?, if so you can not put a tow hitch on the front.
