Depends where the slack is - my guess is a lot of it is worn thrust washers in the centre diff. Confirm this by seeing how much disappears when you lock the centre diff. Other slop is likely to be wear on bearings or on bits that while not particularly difficult to replace, end up pretty expensive without a lot of result. Pull the bottom cover off, and see where the slop is. If it is due to play on the bearings anywhere, these should be replaced, probably not a terribly large job.
