Results 1 to 10 of 18
Thread: Diesel into 101 ambulance ?
    Jan 2008
    Greater Sydney Area
    Hello all - just wanted to throw this one over to the brains trust,
    As much as I love my 101 Ambulance 'Thirsty Kirsty' I have been toying with the idea of fitting some sort of diesel engine. I used it as a daily driver, well every other day really, and she's starting to feel just a little 'tired'
    I believe there is another 101 ambo here in Perth fitted with a Perkin 'phaser' engine.
    Does anyone know of any Japanese Isuzu/Nissan diesels or Landrover Tdi's that can be successfully fitted with a minimum of modification.
    In all other respects I want to keep the vehicle as an Ambulance with an aircon as the only visible change to it's military appearance.
    I use the vehicle to do a fair amount of on road towing and eventually want to travel around Australia next year. Top speed is less important than economy and lugging ability. Just to complicate things I often go serious off roading in remote parts of WA.
    Any advice or opinions would be appreciated..
    Phill
    REMLR 118
    Jan 2008
    Nowra NSW
    Stick with a rover V8 as I feel it makes the vehicle.
    LP Gas is the go.
    I think a 4.6 litre motor is perfect for a bit of zip.
    The TDI 300 just fits and there is information on doing this some where, I have also heard the TDI is not too happy about pulling the 101 around at speed due to the constant wind drag of the 101.
    Gearing with a Diesel is no problem as one of say 4 littres would have the torque to use higher ratio diffs.
    I question If the weight increase with standard steering and brakes is worth the effort as is the increase in noise(sitting beside the motor).
    A 4.6 rover 8 will work easier than the 3.5 and on gas would be the same cost to run as a diesel.
    A diesel takes alot of effort to fit in a 101 as the width between the engine mounts is narrow, gear shift changed etc.
    The motor I would choose is the Isuzu motor as used in the Perentie Landrovers as it already used with the correct gearbox on that vehicle
    (if it fits)
    Also remember the 101 has a special short bell housing and tail shaft lenghts front and rear is critical and it is not a good idea to move the transmission forwards or rearwards.
    To me the rover eight is a good donk and is a good match with the rest of the vehicle from a drivers point of view to weight balance and the fact the body is cut out in a way to allow most work to done in situ with this motor.
    Just remember the 3.5 motor is the smallest one of the V8s and LP gas is not a problem to them.
    LPG tank placement has been worked out to perfection on 101 blood boxes over seas.
    Ron
    Jan 2008
    Nowra NSW
    http://f1.grp.yahoofs.com/v1/YAyVSVI...20page%201.jpg
    http://f1.grp.yahoofs.com/v1/YAyVScA...20page%202.jpg
    The above may not work as it is from a private site but is about a 101 blood box TDI 300 conversion ..... the machine is called tigger.
    OZ101 Guest
    Hi Phil.... Did I read right, have you put aircon in your 101 Ambulance, if so can you give me some info on how you did it, type etc.
    adam
    Central Queensland
    what about using a 4BD1T?
    Jan 2008
    Nowra NSW
    British 4WD still may have the Nissan diesel 101 for sale ?
    Quote Originally Posted by Sprint View Post
    It is too heavy for a 101.
    101 diesel
    hi phil
    i thought about putting diesel in my 101 went into costs i think like ron said you better to go gas the cost of buying diesel you spend 6000 easy to set it up
    plus with isuzui lot of extra weight on front end
    if i had to repower mine i go fuel inject motor v8 and put 400 ltr gas tanks which give me range of 1600 km
    so hope this some helpi
    cheers cooee
    Jan 2008
    Greater Sydney Area
    Thankyou for all the feedback. That private site featuring the 101 conversion doesn't come up. I haven't put aircon on 'Thirsty Kirsty' yet but it certainly is near top of the list - engine cabin temperature, even when trundling down the road, is unacceptably high despite after market insulation.
    The reason I am not contemplating gas conversion is the initial cost and the problem of where to place the tank (s) as the inside of the Ambulance body is NOT a safe or practical option in my opinion - I live in there when I'm travelling. Outside I have long range fuel tanks (very well hidden - can't even tell) which give me an extremely good range.
    For the time being I will stick with the factory 3.5 petrol V8. I have another short block 3.5 which I believe is bored and has a mildly warmed camshaft - ex Triumph race car apparently. The best solution is to recondition the second motor and have it on standby until the current one gets too 'tired'.
    I'm pretty happy with the decision to keep it as original as possible afterall.
    Thanks once again to all the members whom offered advice.
    Phill
    Phil,
    Are you a member of the 101 club in the UK - a recent article in their 6 Stud magazine is about putting a 200TDI in a 101 ambo and it seems to have worked well with the engine pulling OK once it got onto boost - there is an adaptor that mates the 200TDI to the LT95.
    Gas tanks inside a vehicle is not an issue - many new fittings in cars and other vehicles have them inside. If you were concerned about a gas leak then just install a gas detector inside to give you warning and piece of mind.
