and don't say a Falcon or F100
Toss some ideas at me.
Will a 351 fit into a RRC ?
Chevs do, so would a Clevo ?
Can you mate a C6 up to an LT230 ?
Maybe I should just flog it to fix the things that need fixing on the Defender, but it is a damned good engine. 0.040" oversize hypereutectic pistons, Sealed Power rings, 302 2v quench chamber heads with 4V valves and hardened inserts (for LPG) Everything internal was new 114,000km ago, including all the bolts, oil pump, timing chain etc. etc.
Scorcher/Bosch dizzy with a Holden spread cap and HEI, curve to my specs.
Only ever run on synthetic oil and LPG. Very occasionally I would switch to petrol, but the only petrol it would run on was Avgas or PULP with octane booster
Bump stick is relatively mild for torque, it was in my F100 ex-ambo (long retired) that I used for work and towing the race car years ago.
I really don't need a project, particularly if I don't want to sleep with the dog, but it's a damned good engine just sitting on a pallet......
You may need a Atlas Transfer Cases by Advance Adapters, Official Home Page and Dana 60 Diffs![]()
[quote=rick130;915151]and don't say a Falcon or F100![]()
I think it would be a bit heavy, and make the Rangie handle ummmmmm.........Less than optimally![]()
Ritters used to do a kit to mate the c series trans to a machined off LT95, still a few floating around out there. Try rovercare he may have one.
And not to heavy, used to have a 308 and that was fine, also a chev V8 diesel, ok aswell.![]()
Would fit into the Ser3 Landy in my shed
Already setup and fitted with a 302C and C4.
Unfortunately not in the market to buy at the moment.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
rick,
have a look at marks 4x4 adapters. i dont think they do ford to LR adapters but they may have something.
cheers phil
Nobody makes kits, I'd just source a LT95 with C4 and use the factory FoMo Bellhousing etc, make some engine mounts and you in, I don;t have one unfortunately, that how I set up my windsors I had, The Clevo will fit, just be snug setting up headers
