Results 1 to 10 of 15
Thread: hub tool !!
    Perth W.A.
    hub tool !!
    Hi guys wondering if anyone knows where i can pick up a 52 mm hub nut tool external of rovercraft as they have none, and if someone has one(perth) who would be willing to lend /rent as i would like to have a crack at the brakes, when i tried to undo it will a pair of grips (the wheel was off) and the hub just wanted to spin so stuck a pry bar across the studs and broke it ....not happening fast lol
    They obviously are going to be a pain in the 'arris
    NSW far north coast
    Any automotive/industrial tool supplier should have/can get one. It's also the same size as Jeeps (used to) use (2,1/16" )
    Christchurch NZ
    Mine was sold in a hardware shop as a hot water cylinder element spanner, even though it has Landrover on it.
    1995 Defender 110 300TDI :D
    1954 86" Series 1 Automatic :eek:
    Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
    Perth W.A.
    Quote Originally Posted by jimbo110 View Post
    that is the sort of error you want ....have you used it at all ? how much turning does that thing require ? did you leave the wheels on whilst trying to get the thing off so your hub dont turn ?
    Arn't they the same size as the toyota ones??
    NSW far north coast
    Close.
    IIRC Nissan is 53mm and Toyota 54mm. Someone will correct me if I'm wrong.
    I think I used to use a 54mm on GQ's but 53mm was the correct size and GU's use a pin tool. (Why, I have no idea, just another damned specialist tool to make and make sure I don't lose track of )
    NSW far north coast
    I checked mine today and it's actually 2,3/32" not 2,1/16".
    Bought it years ago for my Jeeps and it fits the Defender.
    Perth W.A.
    job done thank f..k used a hire one from odins in balcatta for anyone in W.A. $15 $50 deposit was same fit as toyota slight play so maybe 1mm larger than required thanks for your input guys
    Yass NSW
    Quote Originally Posted by lardy View Post
    Wow.
    My Yota one was $40. My Landy one was only about $15.
    One of mine was about $7 new (a few years ago, admittedly), the other one was $5 at a clearing sale, including for that a 2.25 distributor, a steering relay, and an assortment of other bits.
