Results 1 to 10 of 13
Thread: Bucket Seats
    Tommy Guest
    Bucket Seats
    Hello everyone
    I would like to replace the original seats from my S2A with a set of bucket type seats.
    I would like a set that require minimal modifications to fit, sit as far back as possible without making me feel like a 'Tin Soldier' and I would like them to be as low as possible so that I don't have to look through the top 3 inches of the windscreen
    Has anyone fitted a set that would suit my requirements and from what vehicle do they come from?
    Mareeba
    Imported small jap cars have really low profile seats. There are some places that import front halfs of such cars just for motors so they flick the seats real cheap. I put a set of pulsar seats in my 2a and theyre a bit taller but super comfy. I welded inch square tube directly onto the seats mounting brackets. The square tube sit tight inside steel frames on the landy seat box. With the passenger seat I did the same but did the square tube in three sections either side. the front and back section welded to seat frame and middle section to the seat box. Through the square tube i've run steel rod to hold the three pieces in place. This lets you remove seat so you can still use you're box under the seat. Works well. Will post pics if you're interested.
    Tommy Guest
    Sounds good Woza. Please post pix
    Narrogin WA
    Don't spose you have the old seats you want to part with Stuart?
    Cheers Chazza
    Caboolture
    I had a set of gemini buckets out of the old style rounded gemini coupe in my series three. They were good seats that let me fit behind the wheel (six foot and havent missed too many meals )
    99.87 MB
    Quote Originally Posted by wozapinin View Post
    I'm in the same boat and hoping for seats with bolsters that suit the space. I'd never thought of that - something like a Pulsar SSS seat would probably be excellent.
    Slunnie
    Tommy Guest
    Quote Originally Posted by chazza View Post
    Cheers Chazza
    With a couple of seatless S2As sitting in my garage...I don't think so Charlie
    Tommy Guest
    Quote Originally Posted by Mick-Kelly View Post
    How old is the Gemini now, 30-35 yrs? I wonder if any still exist. Worth a chase around as they warrant further investigation
    Mareeba
    here's my seats, forgive the average art work
    they tilt forward and move back and forth on the original runners. you can see the original seat in the middle, not much hieght difference.
    clean32 is offline AULRO Holiday Reward Points Winner!
    SA, Newton
    so even pink aliens drive Landies
