Results 1 to 3 of 3
Thread: Clutch Slave Cylinders
    DougLD Guest
    Hi All
    I believe that you can get your old slave cylinder relined with a Stainless Steel liner i was wondering where you can get this done and can the master cylinder be done as well.
    Doug
    May 2002
    Heathcote (in "The Shire")
    Quote Originally Posted by DougLD View Post
    Hi All
    Doug
    Any good brake place should be able to get it done for you.
    After my experience though I wouldn't waste my time again.
    Clutch woes
    Now my clutch problems
    Martyn
    Hay Point
    Sure can mate, Most brake mobs do them these days and it is a once off thing usually - no more problems. I reckon they should be stainless from new as brake/clutch fluid is hygroscopic (absorbs moisture)..........Bearman
