Thread: Air Intake Grille
    scanfor Guest
    Air Intake Grille
    Some little Herbert with a screwdriver decided to lever off the fresh air intake grille on the RH wing (300Tdi) while I was parked.
    The little black clips broke off and are still in the bodywork. Does anyone have any tricks or tips for getting them out please?
    I hope that I can get a replacement part relatively quickly, but would it cause any damage to drive around without it for a day or so?
    Oct 2007
    wetherill park
    Should be ok grill is there for looks and to stop branches getting into air filter or is it your heater inlet either way its not a great problem.
    JamesH Guest
    Did I read somewhere you can get steel ones? Mine has broken either overtightened, old, received a knock or all of the above.
    scanfor Guest
    yes, I think i saw s/s grilles at MR in Redcliffe - might look a bit naff on the Defender though methinks.
    Nowra.....
    Did someone say snorkel?
    Sounds like a ripper of an excuse to fit a snorkel instead of playing around with a replacement grill.
    aew849
    2004 130 DCPU - "Bev"
    Dec 2008
    Just fitted my snorkel
    I've just fitted a snorkel to my Defender so if you want the old grille, you're welcome to it. You don't say where you are, but I'm in Brisbane
    scanfor Guest
    Vin
    Thanks for the offer, I´m in Cleveland, but I would be happy to travel to pick it up from you.
    I did contemplate the snorkel option, but I just can´t bring myself to spend $400 on a bit of blow-moulded plastic yet - maybe one day.
    Thanks again
    TBA
    Hey mate
    If you still had the clips in your bodywork, have a look here. Some photos of when I did my snorkel
    http://www.aulro.com/afvb/projects-t...-defender.html
    Just push the centres out (push in towards the engine bay)
    Quote Originally Posted by scanfor View Post
    Quote Originally Posted by THE BOOGER View Post
    As Booger asks, is it your cabin air intake or the engine air intake?
    scanfor Guest
    Ron
    It's the engine air intake - Jock's piccys are right on the money - good tip about the centres just pushing through too thanks.
