17th February 2009, 01:00 PM
NEW AT TYRES FOR D2 - ANYONE KNOW OF LT IN 70 PROFILE?
Hi all. I have failed to properly rotate my Pirelli's AT often enough - shoulder wear. They have always had the problem of following the more severe contours of the highway at highway speeds, which, with a boat on the back isnt a nice feeling in your gut. Apart from that they are sensational, but I think the tram tracking is because they are 265/70/16....although that makes them fantastic on sand which for my unlocked manual V8 is a very good thing. It could be that the tram tracking much worse with the 2 tonn boat off the end is because they are not LTs and allow for quite a bit of squirm? My 95 D2 runs 245/70/16s in the same tyre except it is the LT and it never ever squirms with the boat on the back.
So that is my problem. Is it the softer sidewall and carcass generally that is my problem or is it the sheer width (new shocks, alingment, balance and new steering dampner have not made much difference)....I am reluctant to go smaller because the higher tyres are really excellent on sand and I like the extra height under the diffs generally. I dont think anyone makes an LT in the 265/70/16....any ideas?
17th February 2009, 01:12 PM
Just spoke to my mate who owns a tyre shop and his reply was " I am not aware of any tyres of 265/70 16 in an LT you would have to go up to 265/75 16 to get an LT"
I don't know if this answers your question enough... but good luck hunting.
Doc
17th February 2009, 01:20 PM
Thanks mate - it does...still have the problem of not knowing whether its the size (width) that is causing the tram tracking (can someone else let me know if they have the wider tyres that suffer the same problem or not at all..especially on the highway with a load, or its the lack of LT....I suppose either way Im stuffed because of no LT in that size and have to go down....cant go up because it will gear up the manual truck too much for hill starts for the boat...
Cheeers
17th February 2009, 01:33 PM
#4
I see that the Bridgestone Dueler in the newer 694 does an LT in 265/70/16 - local quote $309 fitted and balanced...anyone know these, I havent been a fan of Bumstone since owning some early duelers in the 80's
17th February 2009, 01:42 PM
#5
,,,these are the specs from B'Stone's site
Bridgestone D694 (265/70R16 LT)
265
70
16
117
S
779
OWT
17th February 2009, 02:27 PM
#6
Ok - I have solved all my problems at the one time...ordered General Grabber AT2s 245/75/16 Light Trucks 10 ply speed rated S. Still go my height (774 versus the current 778) and 10mm wider than standard, so combined with the 120 load rated LT carcass no tram tracking and good towing!
Sweet.
17th February 2009, 02:39 PM
#7
I'm running Cooper STT's in that size.(265/70x16LT) Has the largest outside diameter that is still legal in ACT.(if the speedo has been corrected.
The tram lining is prob' because of the negative camber Discos run. / \ .
Mine does this and did so on the AT's it came with.
17th February 2009, 03:26 PM
#8
The tram tracking must be made worse because of the size though because it didnt do it new with the 235 XPCs on there and my 95 does not do it with 245/70/16s in Pirelli AT LT
17th February 2009, 07:10 PM
#9
You realise just how much better the LTs are when you see that even though the 245/75/16 is a smaller tyre in terms of width than the 265/70/16 the smaller LT is 2 kg heavier and can run a max pressure of 80psi versus 44 for the larger tyre.
18th February 2009, 01:20 AM
#10
Rounded shoulder tyres tend to track more from my experience..
Also, what pressures were you running in the old tyres?
Is your vehicle lifted? How much?
So many variables, but yes the stiffer construction of an LT will help reduce squirm.
