Results 1 to 2 of 2
Thread: D2 V8 Maf , Scangauge and Maf cleaner
    Slow Disco Guest
    Finally worked out that Maf was the running problem - only 5,000km old (no power, backfires)
    Hooked the scangauge up
    Looked for open/closed loops - appeared to working ok
    No faults logged
    Disconnect maf - car running well, no dip in revs when free revving (car in park)
    Hooked maf back up - problem still present
    Removed suspect maf
    Put on a old maf which had been backfired thru - cleaned it first with Maf cleaner
    Fault logged as maf - cleared fault
    Went for a spin, car fixed
    Amazing that the Maf cleaner appears to have improved the old maf previously backfired thru
    I have about 4 genuine mafs which I had removed due to lpg backfires (result of lpg installer incorrectly installing the injector sequences - that's another story).
    So - Scangauge was helpful and I'd recommend some Maf cleaner, available at Supercheap for $23 from memory.
    NSW SW Slopes
    I clean the MAF in my TD5 whenever it starts to get hesitation - sometimes 2K kms and other times 20K kms between cleans.
