Dad decided to knock up some recovery points during the week for the county
CHEERS TIM.
Dads-
http://www.aulro.com/afvb/members-ri...-progress.html
Mine-
Mums- stock 92 200tdi d1.
im not a welder but they look good to me its a good solution to recovery points, or lack of them.
just hope those bolts are HT?
Dads-
Mine-
Dads-
Mine-
1995 Defender 110 300TDI :D
1954 86" Series 1 Automatic :eek:
Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
They look good, I am just suggesting that next time it may be better not to weld all the way around. You run the risk of a bit of undercut and the heat put into the rod may harden it a bit. The result is if you are pulling a bit off dead center the rod may wish to bend, work harden quicker then snap just in front of the last weld.
Maybe if on the rod even if one horizontal weld was 10mm back from RMS and the other side of the rod was 5mm back
Dads-
Mine-
Dads-
Mine-
