Thread: Puma: What length bolts on seat mounts?
    dmdigital's Avatar
    I've gone and done something silly...
    Measured up the size for the grub screws I need to fill in the holes when I remove the rear seats but forgot to write down the length I need.
    They are all M8 bolt but can someone tell me how long they need to be? That way I can buy the quantity I need.
    I'm in Victoria and the Puma's back in the NT.
    Jul 2003
    Hi Derek,
    Are you talking about seats 6 and 7?
    If so are they fixed to the captive threaded washer shaped nuts visible under the wheel arches?
    On each side there is a pair of two on the vertical face and a pair of 4 on the sloped face each being forward and rearward of the wheel.
    These nuts are only about 5 mm thick plus the thickness of two skins say 3 mm.
    Mahn England
    Ex 300Tdi Disco:
    dmdigital's Avatar
    That's the ones and also the seat release so there's a few more bolts. Looked like two weren't captive either so have check them when I startunbolting next weekend. I think the bolts were more like 20 mm when I remove a couple.
    Any chance onscreeing one and checking?
    Jul 2003
    I didn't didn't take up the "two rear seat option" so I'm stumbling around in the dark (metaphorically and literally) here....Imagining where things would go.
    Is the seat release located on the rear tray towards the centre of the vehicle and therefore visible by flattening oneself out lizard-drinking like and crawling under the beast?
    I'll have a gander early tomorrow anyway.
    Mahn England
    Ex 300Tdi Disco:
    dmdigital's Avatar
    Thanks Mahn but I got some more info off Defender2 forum and I should right with 15mm grub screws.
    Are you coming to Wandin?
