If you have 762 springs in the rear it must be a 90 as the 110 and 130 have different sized rear coils. Rangie, Disco and Defender front coils are interchangeable but only the 90 has the same sizs rear coils.
755 and 754's are for 110 and 130. How high do you want it to sit? if it's a 110 If you put 764 in the front with the bar and 755's in the rear with a 20mm solid spacer under the rear spring base it wil be about 2.5 inches above standard and flex and ride surprisingly well. 764 are a 220lb disco/rangie rear coil but work well in the front of a Defender.
