Results 1 to 10 of 22
Thread: Damn dust..... Snorkel Pre Filters on Defender?
    Oct 2008
    Ok - I live on a dirt road - it's only 5 ks long - but this year the dust has increased beyond belief. I'm blocking air filters after only 30-40 trips on this road, particularly if I'm following someone.
    I have a snorkel on the TD5 but that does not really help, my PUMA has no snorkel and sucks it's air from the wing.
    So has anyone dealt with this sort of dust issue, are there any pre filters that can be fitted to snorkels that work at 60k's? I've seen the Donaldson's pre filters but those appear to be designed for agricultural and slow moving vehicles, and apparently above a certain speed the filtering effect is lost ,and it dumps straight down the chute. Anyone experienced this?
    NSW SW Slopes
    I use a Donaldson pre-cleaner on my TD5 D2 when the dust is bad enough. I've read about it not working at higher speeds but have evidence that it still collects dust. I don't use it all the time due to the extra noise and I suspect it might increase fuel consumption at higher speeds/engine loads.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    i had one on my last 300tdi and found it actually improved the performance of the vehicle. made less noise than the usual snorkel head as well...
    was still on it when i sold it..
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2002
    Heathcote (in "The Shire")
    I use a donaldson pre cleaner for desert trips (or if I think it going to be dusty)
    Last trip it certainly collected plenty of dust/sand and if the fuel consumption was higher, it wasn't enough to worry about.
    Edjits Tour Madigan Line 2008
    I would normally get ~10.5 normal running around.
    Martyn
    We used pre-cleaners and droopies (snorkel socks) on our Simpson - Central Aus Trip. The Droopies collected way more dust than the precleaner did, and the airfilter in the Defender didn't need changing / cleaning. The Droopies are about $40 for a set of 3, they're like a Finer Filter type of foam sock.
    Jan 2008
    Nowra NSW
    There is a precleaner advailible with looks like a normal donaldson one , but is very different inside.
    It works by a spining arm or blades inside on ballbearings driven by the engines inlet air flow through the precleaner.
    The spining effect of the internal parts throws out most of the dust down and out side of the unit so there is no cleaning needed.
    Cummins Aust used to sell them.
    I have seen these units work in the worse conditions with industrail vehicles.
    These things are fantastic, but do have some draw backs.
    Price
    Must be size matched to your engine
    They make a spining sound for a minute or two after you turn off the vehicle while they wind down.
    I think the brand used to be called SK, but I cannot find any reference to that name and this site may be the lastest version of the design.
    Air Precleaners
    South East Tasmania
    Donaldson filters
    I would try the Donaldson brand.
    Among their products they have the Donaldson Topspin
    Look at their catalogue HERE
    Also in their home page HERE
    you will find a section called Air System Accessories wher a range of intereting products are available.
    I hope that this ifo helping you
    Camp Hill Queensland
    Quote Originally Posted by Michael2 View Post
    My vote is for the snorkel socks as well. Used them on the Cape and other offroad work
    '95 110 300TDI, F&R ARB Lockers, Twine Shower, Aux Sill Tank, Snorkel, Cargo barrier, 9 seats, swingaway wheel carrier, MadMan EMS2
    '85 110 Isuzu NA 4BE1 3.6l Diesel, 0.996 LT-95, Rear Maxi (SOLD)
    '76 SIII 109" Nissan ED33 5-SP Nissan GBox (SOLD)
    Tassie/Perth
    Thinking outside of the square - I know of guys that use the 'pantyhose' type anklets that women buy from supermarkets over the head of their snorkel......
    Cairns, FNQ
    Wink
    Quote Originally Posted by cewilson View Post
    Hopefully in private & not on Sundays.
