Results 1 to 10 of 17
Thread: Getting talked out of Lift
    Jul 2008
    Coffs Harbour, NSW
    Hi there, Why is my mechanic trying to talk me out of a 2inch lift? He says all he would want to see on my car is a 1inch spring lift? He is saying issues with handling, castor and the old "front tailshaft". After searching previous threads and the internet for months, is a 2inch lift really going to EXPLODE! (slight dramatisation) the front tailshaft?
    I really want those 265/75/16's
    Thoughts?
    PS: 2000 D2 TD5 Auto 179kms, Sahara bar, winch lights, custom rear bar, drawers. Towing matching (LR Rims 245's) builders trailer every day
    Thanks in advance
    Nov 2008
    Roleystone, Perth
    2000 D2 with a sahara bar? You must post photos and a tutorial on how u fitted it.
    Nick
    I could be wrong but I thought you could get 32's under with out a lift in a D2...I'm sure redback will be along or slunnie to answer your questions as I believe both have a 4" lift in theirs
    Williams West Aust
    265s should go on your D2 @ standard height unless its badly sagging.
    No castor correction needed on the D2 with a 2" lift.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Your mechanics being silly
    But.... Being a 2000 model, I'd recommend rebuilding front shaft at same time..
    Your uni Joints have been running at their current angle a long time and changing that will not help them!
    99.87 MB
    Yeah 2" is very common on the D2, but to fit 265/75-16 you will need a bullbar. I would do it... well, actually I and lots others have. Castor isn't a prob. You'll more than likely find that many 2" lifts only net about 40mm anyway, and full 2" lift will only take most D2's to juuuuust out of spec according to the tolerances given in RAVE.
    But, just be aware of the front shaft and sensitive to any vibrations or noises as they have the potential to be nasty if they break. I do run a 4" lift, but when driving the car hard I will do a front prop every 12 months. Since running bigger unis and reducing the high impact driving the shafts have been living well.
    Slunnie
    Kingston, Tassie, OZ.
    Does your mech drive a Volvo and wear funny hats??
    Seriously speaking a 2" lift on a D2 is a good thing, helps save a bit of the rear plastics etc for one
    It won't upset handling on a D2 as much as a D1, but as Tombie2 and Slunnie recommend, replace or rebuild the front shaft.
    MAKE SURE that decent shocks are used, that is a whole new thread in itself though
    JC
    99.87 MB
    Oi, you leave Sneigy alone! Nah, Sneigy used to run lifts also.
    Really good point about shocks - and I would argue that they make more difference to the ride and handling than the springs. Everybody talks about springs, makes, designs, rates, lengths etc etc etc and then just throw on X brand of shock because jimbob said they were good with many not even checking lengths let alone construction, valving, bush material etc etc etc.
    Slunnie
    Central Queensland
    Quote Originally Posted by Hastykiwi View Post
    Nick
    whats the problem with it? its an ARB product built for a D2
    Quote Originally Posted by Sprint View Post
    Its an ARB product built for the Facelifted D2A only...
    But with a little work can fit a D2
