Results 1 to 9 of 9
Thread: defender gear ratio
    Jul 2008
    defender gear ratio
    hi if have 2004 defender 90 and the gear retio is a bit low for me for road driving. Because i drive mostly on road and some on dirt i thought to change the ratios. What would you suggest to change for a higher gear ratio ive heard tranfer box from discovery any other and is transfer box best thing to do
    yep, Disco high range gears.
    Kingston, Tassie, OZ.
    ...Or 33" tyres....
    Seriously, a 90 will benefit HEAPS with disco gearing. I'll swap you a mint condition 1.222:1 Disco transfer for yours, I'll even pay freight
    JC
    Disappointingly the 33" tyres on mine dont seem to make much of a difference.
    Jul 2008
    Sunny Coast,QLD
    I have put a 1.21 ratio transfer case out of a 98 300tdi disco into my td5 and so far am quiet happy with the result's.
    Does about 2350rpm @110k's and i am getting 9.8 litres per 100km's
    I wouldn't do this though if you are still running the standard ecu as it would be pretty gutless!
    Cheers Shane
    you could also fit an overdrive.
    gearing
    Disco Tranfer works well. Have done this on a 110 before.
    But i have put in a GKN overdrive in my 90 this time. Really cuts the revs for cruising... $$$ if you buy from here though. I modified mine some in the wiring department to reduce the potential fro problems.
    G
    Disco gears up the gearing abount 15%. Well worth it for touring.
    Spend the extra $$ & get the 1.2Q gears from a D2. Q=quiet.. they transform the car on the open road.
    Max P
    Jul 2008
    thanks i have talked to a guy and hes got a defender 90 with disco tranfer case he said it helps heaps. And the best thing is he owns a transmission shop. So he is ordering in a transfer boy and sure it will help thanks for you comments
