Is there a reason to up-grade?.If you put a blob of grease under the cap when you grease the uni's the flanges last a long time,my 13 year old disco still has it's originals. Pat
All
i'm thinking of uprating my salibury rear axle and flanges for hi-tuff or similar, i'm assuming its fairly simple to replace the original items with the upgraded ones?, do you need to modify the diff centre?
Thanks in advance
Adrian
Just done this in my 98 defender.the vehicle is now trim taut and terrific and an absolute pleasure to drive.Also replaced steering damper.
Hadn't realized how slack things had been getting.
Mary
I just did axles and flanges
"Some people walk in the rain,others just get wet!" -Roger Miller
This is a copy of the Instructions from when I upgraded my flanges a few months ago.
Hope this helps...
Aaron & Jacinta
1994 300Tdi Defender
no need to modify the center, Hi Tough Eng. axles and flanges are drop in replacements.
you may want to ditch the oil seal and let the wheel bearings run in oil.
Serg
1998 Defender
2008 Madigan
2010 Cape York
2012 Beadell, Bombs and other Blasts
2014 Centreing the Simpson
VKS-737 mob 7669
replaced mine -rears about 1 month ago and same as those above backlash reduced dramatically, also converted to oil bathed bearings. If you dont do the oil seal thingy its realy quick, -Minutes litraly, removing the seal takes a bit more time and mess. remember to replace the gasket on the new flanges, does not come with the kit but very cheap.
Mal
