Thread: Vista and Windows firewall
    I just replace the old office machine with a new Vista based system.
    Should I use Windows firewall or would Zone Alarm or another aftermarket
    product be more effective?
    Davy
    Nov 2008
    Definitely go for a 3rd party software firewall to reduce the risk of people exploiting known security vulnerabilities.
    Ringwood VIC
    Dunno how it runs with Vista but Kaspersky seems to be pretty good.
    Stu
    St Helena,Melbourne
    4.28 MB
    Dont use zone alarm, it will slow your system down dramatically.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2003
    On The Road
    I use Comodo, one of the few that will run on Vista 64.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    do you all keep the bank of england's records on your home computers?
    want to buy a bridge?
    you need one to get the most out of microsoft's products... really you do.... but you need to run another sextillion mb of ram so you can store the bridge...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    May 2003
    On The Road
    Quote Originally Posted by incisor View Post
    No,,
    but I keep the Bank of Pedro's records there---
    no,, why?
    do I need to get over something?
    I'm sorry I dont understand that,,,,
    I need a bridge???
    is it Sunday afternoon already??
    Hi Davy
    If you have a router as part of your set up just use the firewall in that. Best time saver I ever did was uninstall Zone Alarm. Takes minutes off the boot time.
    Quote Originally Posted by DiscoCam View Post
    Hi Davy
    You really should be using both a hardware firewall (ie the one in your router) and a software firewall.
    The reason for both -
    Most hardware firewalls treat traffic originating from within your PC and travelling to the outside as inherently safe. So if a bad guys does gets into your PC, say via an email you open, your router firewall will most likely not stop it transmitting your details back home. In this respect hardware firewalls are said to be 'stateless'. They have no awareness of where the data originates from.
    Most software firewalls are said to be 'statefull'. A 'statefull' firewall matches incoming data with outgoing requests. They block all traffic which does not specifically originate from a request for data by you.
    So if a bad guy gets in, it can not send data home unless you specifically give it permission to pass through the fire wall. Neither can an outsider enter your PC unknown to you because that data coming to you did not arise from a specific requested by you.
    The best combination is when you have both the hardware and software firewalls working. The hardware firewall because it can't be attacked and the software firewall because it performs 'statefull' data inspection.
    If you don't like Zone Alarm, look for another or use the Windows one.
    If you want to test your firewalls you can try using Shields UP
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Highlands NSW
    2010 110 Crew Cab Deefa
    Mittagong NSW 2575
