                                                4th March 2009, 03:36 PM
			Any 1 fitted an equipe Base kit
					Just after opinions and thoughts of installing the equipe 4x4 suspension base kit stage1 to my fender.
 Cheers.
                                                4th March 2009, 04:09 PM
                                                4th March 2009, 08:49 PM
					To increase suspension flex at standard ride height you need to do four things.
 1. Raise the upper shock mounts an inch, preferably two
 2. Fit much longer shocks (3-4 inch more travel)
 3. Get dual rate style coils with tighter windings at the bottom.
 4. Fit extended brake lines (+4")
 All the above will cost approx a grand.
 The standard links in any coiled county/defender will be good for 12" travel shocks all round at standard ride height and I guarantee that is more then you will need/want to satisfy, hence changing the links is a bit of a waste of time/money.
 In the front you would be best off fitting Haultech Holey Bushes into the radius arms to fully utilise the amount of travel on offer and to even up the flex a touch more front to rear.
 Retain the coils top and bottom for greater stability in 90% of crossed up situations and your done.
 So what shocks and coils are best for such an application? and where do i get the bits to raise shock mounts? and who makes extended brake lines?
 Sorry bout 50 questions but im new to fenders.
                                                4th March 2009, 09:15 PM
                                                #4
			Fitted Stage 1 Equipe4x4
					Yes - I fitted a base kit to my 2005 model Defender abuout a year ago - top grade stuff and absolutely happy with it. Cost me about AUD$1700. I fitted ARB springs and Bilstein shocks giving it a 2"lift. I have had no problems with it at all.
