7th March 2009, 08:00 PM
body lift kit for RRC
any body know of a company that makes a 2 inch body lift kit for a RRC at a reasonable price? and know what exactly is involved , ie: and things need modified to fit it, or are they like most 4x4's and a prety much a straight bolt in swap with very minamal changes needing to be done
7th March 2009, 08:09 PM
Les Richmond auto do a fairly comprehensive kit - Les Richmond Automotive Dont know if it is particularly 'cheap' though...
I imagine there are cheaper options. I hear you get fairly good instructions so that you can do it with a high lift jack and a few mates. It comes complete with the 10 main spacers holding the vehicles body with 8 of these diagonally supported back to the chassis, 4 floor mounts inside the rear wheel arch, 2 under floor mounts under the drivers seat, 4 seatbelt extensions, 2 radiator raising extensions, high-low gear stick extension and brake line modifications for the front and rear.
Angus
7th March 2009, 08:14 PM
thanks for the quick response, i am going to look into it right now
