Freelander Handbrake
The trailing brakeshoe on the rear brakes on a Freelander has a lever riveted to it that activates the rear brakes when the handbrake cable. is pulled. This lever is riveted to the shoe by what appears to be an aluminum rivet which recently failed making the handbrake ineffective. I replaced the rivet with a nut and bolt which worked but now the rivet on the brakes on the other side has failed. I think I will just replace the brake shoes even though they are not worn much. The shoes were made by Lucas - of Prince of Darkness fame.
Any one else had this problem? While mine both failed when putting the handbrake on - they could fail when parked - the design (or at least the Lucas version) is a safety hazard.
