Results 1 to 10 of 38
Thread: Rough Defender
    Mar 2009
    Sarina Beach
    Rough Defender
    Hello All,
    Iam on my 5th landrover and currently own a 2008 Defender.
    Its the roughest ride yet ! Especially in the front end.
    Can anyone with a similar Defender comment about their ride quality.
    Oct 2008
    Newcastle
    I am guessing you haven't had a series land rover yet
    Mar 2009
    Sarina Beach
    Yes, I have had a 1980 4 cyl tray back !
    TeZZaP Guest
    I've has a new Defender 110 for about two weeks, its a lot quieter and smoother than the 2003 90" I have. If you are used to Defenders, the latest ones should feel noticeable better, in the road handling side of things, IMHO...
    Mar 2009
    Sarina Beach
    I had a 1985 110 and recently sold my 1997 Discovery (400 000 km ) and
    the new Defender seems a much harsher ride. The front springs are supposed to be progressive rate . Looking at them the top 4 or 5 coils are sitting down on top of each other . Is this right ?
    TeZZaP Guest
    Quote Originally Posted by Pete1 View Post
    No idea... I'll go and have a look at mine...
    OK, on mine the top 3 rings sit touching each over, the rest are spaced out as you'd expect... no sure if that helps but that's what mine look like. You could go to your nearest dealer and take a new one out for a test drive, then you'd have something to compare your ride to.
    Mar 2009
    Sarina Beach
    Ok . Went and checked mine and there is 5 rings touching now !
    Dealer reckons all ok , but Iam not convinced. Why should any be touching , that the dealer coud not tell me.
    TeZZaP Guest
    Curious, I'll check mine after I've been for a drive, see if it changes.
    Other than that I'm afraid you'll have to wait for more knowledgeable persons than I to help you out, good luck
    TeZZa
    Mar 2009
    Sarina Beach
    How many Km have you done ? Iam averaging about 10.6km /lt on hwy.
    TeZZaP Guest
    no idea, I just fill'er up when its low... I don't want to know either!
