                                                18th March 2009, 05:27 PM
			 oil pump removal on fl1 xedi oil pump removal on fl1 xedi
					hi every one my oil pump is leaking oil past the gasket but im having trouble on how to do the timing can some one help please
                                                18th March 2009, 09:20 PM
					Oooohhh... Not an easy one this.
 We had to replace the oil pump on mine recently as it split while tightening everything up after doing the cam belt.
 We found it easier using one of those engine hoists that sits in the engine bay, removing the sub-frame, engine mounts and dropping the engine down enough to give access. From there, we slackened everything off, which was just enough to remove the pump while in-situ.
 Good luck.
 M
